hello folks I’m in the mood to adapt the mavlink-router conf to get another udp endpoint that will be used on localhost only for translating messages on a different format
unfortunatly there is a bit too mutch of mavlink-router.conf files
I dont know the one is realy use
as it looks /system/etc/mavlink-router.telepathy-air.conf and /tmp/mavlink-router.conf are the same I’ve conclude that it is the one realy used and get copy into tmp at boot (for an unknown reason)
but it looks already in use i get listen udp4 :14554: bind: address already in use
after few more tests 127.0.0.1:14551 looks free for use but I get no messages on it
thank’s for any help
first I’m running this on air unit only
I have a software gateway that translate mavlink message to NATS topics
(this gateway has already been tested before on few different companion computer. )
as it’s very simple and don’t need a lot of resources the idea is to make it run on air unit in order to save use of a companion computer
I’ve succeeding in putting a usb to 4G modem on air unit it’s working great even if I still have no DNS working ( every thing about this here : Usb_modeswitch on air unit - #20 by Olivier_Gasté )
