Hi
What is the maximum GPIO input voltage for Cube Orange?
I want to connect the RPM sensor, it outputs a 5V level signal. Is it
acceptable? Should I use a 3.3V sensor instead?
Thank you
Hi
Thank you
Hi
May I ask which carrier board did you use ?
GPIO is 3.3V.
Best regards,
Mike
Hi
Thanks for reply!
I use default configuration for Cube Orange with original carrier board. It is named ADS-B Carrier Board on some sites.
