Mini Carrier Card/CubeOrangePlus Schematic
I’m using a CubeOrangePlus on a Mini carrier card. Where can I find the schematic for the mini carrier card and the CubeOrangePlus? I’m looking to repurpose I/O pins and need to trace port pins on the mini carrier card to pins on the STM32H757.
Thanks in advance for your support!
There should be everything you need here:
With most carrier boards, they contain almost no electronics and are just an “adapter” to expose all the connections. Apart from the power brick, all the electronics are inside the Cube.
There’s some circuit diagrams here:
