i am trying to connect my rtk module which is Here+ RTK Base to Mission planer by the menu on right top but when i try to connect it first says
right after this time finishes
but when i try to connect it in U-center 2 it allows me and works perfect
but i need to use this application because in u-center 2 i couldn’t train it because it says my rtk deosn’t support time mode so i should do it in this app
i tried every baund rate and it didn’t worked out too
by the way my error is
Can not establish a connection
No Mavlink Heartbeat Packets where read from this port - Verify Baud Rate and setup
Mission Planner waits for 2 valid heartbeat packets before connecting$GNGSA,A,3,05,22,07,08,13,14,20,30,2.00,1.00,1.73*16
$GNGGA,142804.00,4127.26866,N,03146.03946,E,1,11,1.00,1.2,M,35.3,M,*4A
$GNVTG,T,M,0.005,N,0.010,K,A*39
$GNRMC,142804.00,A,4127.26866,N,03146.03946,E,0.005,240924,A*6D
$GNGLL,4127.26864,N,03146.03948,E,142803.00,A,A*73
$GLGSV,3,3,10,87,02,356,30,88,02,047,27*6E
$GLGSV,3,2,10,73,10,230,78,04,043,23,79,53,030,20,80,64,249,29*6B
$GLGSV,3,1,10,68,10,148,69,60,150,26,70,49,323,25,71,02,327,36*65
$GPGSV,3,3,12,20,35,237,32,22,43,195,33,27,00,026,16,30,70,032,29*7B
$GPGSV,3,2,12,13,39,309,28,14,64,179,25,15,08,311,32,17,01,160,*72
$GPGSV,3,1,12,05,41,277,43,07,42,064,29,08,16,052,30,09,17,127,21*76
$GNGSA,A,3,80,79,69,2.00,1.00,1.73*13
$GNGGA,142803.00,4127.26864,N,03146.03948,E,1,11,1.00,1.2,M,35.3,M,*41
$GNVTG,T,M,0.005,N,0.009,K,A*31
$GNRMC,142803.00,A,4127.26864,N,03146.03948,E,0.005,240924,A*66
$GNGLL,4127.26863,N,03146.03952,E,142802.00,A,A*7E
$GLGSV,3,2,10,73,10,230,78,04,043,23,79,53,030,17,80,64,249,30*67
$GLGSV,3,1,10,68,10,148,69,60,150,25,70,49,323,25,71,02,327,36*66
$GPGSV,3,3,12,20,35,237,33,22,43,195,33,27,00,026,16,30,70,032,29*7A
$GPGSV,3,2,12,13,39,309,28,14,64,179,26,15,08,311,33,17,01,160,*70
$GPGSV,3,1,12,05,41,278,43,07,42,064,29,08,16,052,30,09,17,127,21*79
$GNGGA,142802.00,4127.26863,N,03146.03952,E,1,11,1.00,1.1,M,35.3,M,*4F
$GNVTG,T,M,0.004,N,0.007,K,A*3E
$GNRMC,142802.00,A,4127.26863,N,03146.03952,E,0.004,240924,A*6A
$GNGLL,4127.26862,N,03146.03955,E,142801.00,A,A*7B
at MissionPlanner.MAVLinkInterface.OpenBg(IProgressReporterDialogue PRsender, Boolean getparams) in C:\Users\mich1\Desktop\CubePilot\MissionPlanner\ExtLibs\ArduPilot\Mavlink\MAVLinkInterface.cs:line 886
at MissionPlanner.Controls.ProgressReporterDialogue.RunBackgroundOperation(Object o) in C:\Users\mich1\Desktop\CubePilot\MissionPlanner\ExtLibs\Controls\ProgressReporterDialogue.cs:line 111
this if its helpful
thank you ![]()
