Dorian
(Dorian)
7 May 2021 15:50
1
I just built a new quadcopter equipped with a Black Cube, Here2 antenna and Herelink.
I regularly encounter a message at startup with QGC: “Mission transfer failed. Retry trasnfer. Error: Mission read failed, maximum retries exceeded”.
The Cube has well gps mission in memory, because despite the message, if, during a flight, I select Auto mode, it works correctly.
However, if I try to manually download the mission, it does not work and I cannot execute the Auto flight command and there is an alert.
Do you have a solution for me?
Dorian
(Dorian)
9 May 2021 12:23
2
I have tried again and still have the same problem in about 1/3 of the starts.
I have to reboot the Cube or the Herelink for the mission to load correctly.
I had read this post before contacting you, but I don’t know if my problem is really similar and I did not fully understand the procedure.
This is my eighth HL and this is the first I have encountered this problem with.
Any idea why I cannot upload missions from QGC to the drone since firmware updates? Same error with Geofence etc.
Also get an audio message about Mavlink?
Thanks in advance.
Alvin
10 May 2021 06:29
3
The solution in that topic is
Go to QGC app > click the Q icon at top-left corner > Click Comm Links > Click Add to create new link configuration
Type: UDP
Listening Port: 14551
But I’m not sure if this will help.
You may try to reflash the firmware on Herelink controller.
Dorian
(Dorian)
10 May 2021 14:42
4
Thank you for your reply.
I made the change, but it didn’t change anything.
I will try to reflash the HL
confirm if you have mavlink 2 enabled on the comport
Dorian
(Dorian)
3 June 2021 19:54
6
Hello Michael,
Sorry for my late response.
The hardware is no longer in my possession and I can’t remember if mavlink 2 was enabled.
Thanks for your help.
