@philip is it possible to run hereflow and Here V2 GPS in CAN mode and on the same bus? Might be a stupid question as I can’t find any info on this subject.
@philip awesome! Now that Here is working on the Solo in CAN mode I want to step it up a little. Will it use info from both devises or just the better of the two?
trying to install the here flow, with no success.
I have also a germin lidar v3, which works perfectly, but not success with here flow.
I think I missing something here, but I don’t know where the problem is.
I also trying to work with them both, but how I can use both of them?
Is this still a work in progress? I am currently using a Hereflow looking downward and I want to implement another one looking upward. I have a pixracer with only one port CAN but in theory it should still be possible to connect them in parallel, right? Any guide would be appreciated
