Can I transfer NMEA output using telemetry port2 in cube , How I can do that @Michael
I tried SETTING like
Serial2 Baud-57600
Seraial2 protocol -20
Radio - RFD900+ with Same ID on both(Air and Ground)
what does the output look like?
$GNRMC,143909.00,A,5107.0020216,N,11402.3294835,W,0.036,348.3,210307,0.0,E,A*3. it will look like this
I know what NMEA looks like, I’m asking what’s coming from the Telem port NOW.
Have you confirmed the port is good? Is the port able to output Mavlink? Do you have a TTL<->USB (FTDI) adapter that you can check the output?
No I am not getting nothing
