No Airunit, Wifi only possible?
We have a problem that stick movement from the Herelink isnt registered on the mavlink protocol.
Our situation. We have the OrangeCube connected with USB to a PC. On this PC we run mavlink proxy and we output via UDP to the herelink which is connected to the same network via Wifi. The Herelink receives mavlink. When we move the sticks on the Herelink, we dont see any mavlink rc channels getting that input.
When consulting the manual we dont see a wifi only setup, the Airunit is always used to connect to Telem1. Is what we are trying to do not prossible? Cant we tell herelink to pass the stick movement to mavlink? Do we need to use the Airunit?
Thanks in advance.
Bastiaan
