I have some issues with my gps, when I do calibration, it seems like it’s working.
But mission planner says No gps when it’s pre-arming.
For information, I soldered the wires of the gps to wires going on the connector of the cube (It may be the problem, like bad solder or wires inversion even if I don’t think so)
By the way, I have this in EKV doing nothing.
When you can you have calibrated the GPS does not get calibrated. The compass does and while these are in the same housing they are independent sensors on the GPS1 port and have different data bus types.
I found this for my gps, can you tell me which one are for the compass and for gps ?
And if Tx of my gps go on tx or rx ? because currently its Tx to Rx and Rx to Tx
Also, can all be connected to GPS1 ? Because the compass working, maybe it’s just 2 wires to modify ?
@Mallikarjun_SE Okay, it seems like it’s working now, I did the Rx and Tx swap, and GPS_TYPE was already auto. Now it says No fix GPS but I think this is just because I am indoor. Thanks for all
EDIT : I have bad EKF Vibe, what does it mean ? ( I have EKF in red color, and when I click on, I have this :
