Hi
I recently updated both my herelink and airunit am working with cuav CAN PDB board and x7+ with herelink I am not able to see any rc inputs to the board I am verifying it with Qground control on herelink as well as USB connection to the mission planner
Rest telemetry and all other things are working fine also the herelink settings are all good to go
yes Recalibration of controller has been done and movement is sticks is reflected in herelink settings app but not in mission planner I check the pixhawk worked with a futaba sbus input and hence assuming it should work with herelink too it worked before but now its not working
please tell your version .if gcs is old version then try registered as beta version in update pop it show on left corner 'register as beta.this is for air unit 1.1 with gcs 1.0
Hi I still couldnt solve this issue It was all working but when i updated the firmwares the rc sticks stopped working right now my firmwares are as follows:
Airunit:
Online Version : AAU01211129
Local Version : AAU01211129
Now i couldnt get any rc control in mission planner via usb as well i do not see any control on the qgcs on the herelink although i can change modes with the abcd buttons
Hi I am using Can pdb cuav and x7+ i tried using frsky sbus and its working… but herelink sbus isnt moving any stick in radio calibration i checked in herelink as well as usb connection to mission planner…
Also confirmed that herelink is working with cube orange which i have on another setup so seems some prb with configuring the can pdb or something is weird can u help?
