No SBUS input
Just purchased a new herelink 1.1 setup. Coming from the older 1.0 version hardware and have flown plenty of orange cube/herelink previously.
Unfortunately, I’m unable to get any SBUS signals - I have been working this problem for about a week now. I see many other having the same issue and there is a lot of writing about firmware versions but none seem to write that it actually fixes the issue. So, here is what I have:
  • Air unit version: AU01230714
  • QGC version; RU01240301
  • Orange cube+ and standard ADS board
  • Air unit and controller is paired
  • Getting telemetry, GPS position etc on controller
  • No RC input seems to get to the cube
Here is what I have tried:
  • Reinstalled firmware (not beta) multiple times on both air unit and controller
  • Recalibrated sticks and SBUS on controller
  • Messed around with sbus cables
What I would like som input on:
  • Am I missing some parameter settings on the cube? I have attached a zip of my current parameters.
Anything else I could be missing?
params.zip (5.2 KB)
@sidbh @philip
Which carrier board?
Have you got a photo of your wiring?
Since you have been shuffling firmwares it is possible you have loaded incompatible versions on the hand controller and the air unit.
Please contact your reseller for support.
Already have. Awaiting their reply.
The physical connections look good.
You need to set RC_PROTOCOLS,8
Currently you have RC_PROTOCOLS,2 which is PPM. You could use 1 for everything, but I find it handy to set the value for the specific protocol in use to be sure expectations are met.
Makes no difference unfortunately.
