Solved. unplugging and reinstalling the 3rd time solved it ( HPFM)
No how to calibrate the ESC ? what LEDs are described in the manual?
“The autopilot’s red, blue and yellow LEDs will light up in a cyclical pattern”
I only have LED’s under the Cube orange and on there HERE3.
Also how to put in ESC Calibration mode when I don’t have a safety switch?
BRD_SAFETYENABLE,0 also definitely exists, you’ll find it in the Full parameter list of MissionPlanner, also all parameters are available in QGC but they get broken up into some level of “difficulty” or common usage.
You might as well find it and set it to 0 (or disabled) and leave the safety switch out of you build, since it’s more like anti-safety.
