I have a HereLink system with the following model numbers:
Ground Unit: HX4-06075
Air Unit: HX4-06074
I am trying to pair them since there was no communication out of the box. In the manual, its been instructed to go to D2D info in QGCS where there should be a display of frequencies received at the ground unit. I see a blank D2D screen. I went through the following topics:
But, unfortunately, none of them seem to be linked to mine. And I could not pair using the standard procedure. Screenshots are as below:
Ground unit D2D screen:
I also successfully upgraded the firmware of both Ground and Air unit and the screens shots are as below. Even after upgrade, I get the same result…
Airmodule update screen 1:
Hello @sidbh,
Thank you for the response. Please find attached video link of the process that i am following. Do let me know if i am erring in any way.
please do an update to both the air and ground unit using the latest firmware. Make sure you run the entire update and CLEAR the STORAGE as well. ie “flash_all”. this just ensures the update has no old settings that could cause issues,
Hello @Michael_Oborne,
Thank you for the suggestion. I did the same, but to no avail. Both ground and air unit were on the latest firmwares on the day of raising the issue.
Regards,
SH
The air unit LED2 lights up on power on and with steady amber color. When i press the reset switch for 3 secs , it changes to blinking green and stays that way for a minute or so. Since the pairing process is unsuccessful, it changes back to steady amber. LED1 never lights up.
