I have Cube Orange board (Chibi OS 4.0.0). I have followed this link for the setup “Benewake TFmini / TFmini Plus lidar — Copter documentation ” but still not not able to detect. LiDAR attached on I2C
Can anyone help me with this issue?
Thanks & Regards,
Deep Chokshi
Mike_ZY
(Mike_ZY)
27 June 2022 05:29
2
Can you try this Lidar with another cube?
Is that I2C port on your cube function well?
Did you reboot after setup?
What shows on GCS?
Were you able to complete this sucessfully…
Yes, @sibujacob it is working. I have configured with Telemetry port 2. It is working fine.
Can you connect more than one x “[Benewake TFmini / TFmini Plus lidar ] . OR is it that only 1 is possible.
Td1230
(Anthony)
10 April 2023 01:07
6
Having a similar issue on my cube orange ic2 “rngfndr not detected” issues, with TFmini-s, both tele ports in use, any other options
Can you access the PX4 Mavlink console and check the output of following command
i2c detect -y
Iam also facing the same issue with the TF-Mini plus lidar connected to i2c2 port of pixhawk cube orange +
i can see the change in the sonar range but iam getting this error message(PreArm:RNGFNDER_NOT DETECTED)
