Orange Cube+ Late Connection Issue
Hello, I use orange cube+ for fixed wings. I uploaded the firmware to orange cube+ without any problem and orange cube+ worked perfectly. Then I started the make calibrations. First I made accelerator calibrations. And it worked. Second, I made compass calibration but after rotating the orange cube+ in all directions. MP notified me that I needed to reboot the orange cube+. After I reboot the orange cube+, I connect the computer, Orange cube+ gives the melody that it can be connected very late and different to usual therefore I can connect very late.
Connect Melody
Any one?
Sound indicates no sd card or bad SD card.
But orange cube+ is opening after while. What should I do? Should I change the SD card? Is that make any other problem. Thank you so much for your help.
Yes. Swap SD card and check.
It worked. Thank you so much for your help. I really appreciate that.
