I am using Pixhawk cube. there is a built-in ads-b receiver. but there is no transmitter. how do i set up an ads-b transmitter ? What should I do to see my own plane on the flightradar24 ? There is a squawk code in the parameter list, I think I can broadcast ?
Hi. There is no need of transmitter. You can change some parameters in mission planner and set the ADS-B to see all the planes and also avoid them automatically without requiring any actions from that ground pilots. Take a look at this user guide for setting up the ADS-b in the mission planner and this guide also helps for the parameter settings :- Link : - ADS-B IN Carrier Board - CubePilot
You can directly see all the planes approaching in the q ground control maps. You will see a icon actually on the q ground control maps and also you can see in the mission planner map. No need of any other transmitter. Hope it helps.
The same is also explained in this madrc video in youttube which is explained more properly with video demonstration along with testing. Link :- The Cube Orange Autopilot/Flight Controller With ADS-B Overview, Setup & ADSB Demo - YouTube
Hope this video also helps you. …
To see your own plane position on map, you can use the gps of your copter.
There is no ADS-B transmitter in ADS-B carrier board. It is a uAvionix ADS-B IN Receiver.
Yes there is the parameter ADSB_SQUAWK and I’m not sure how it works. But setting a parameter won’t make a receiver become transmitter. You’ll need additional hardware.
Hi, You will need a transponder to do so. But dont just squawk a code if you have one. If you are not sure how it works dont use it! (plus a transponder is really expensive) . Best regards!
