Hello all,
I will use 6s LIPO 5000mah X 2 and I’m scared to burn the battery or drone when I connect the power.
I heard that configuration “2” is the best.
but, I have 2 battery monitors and I dont want configuration “2” because I have to buy or make “Y” cable.
I do not want to make “Y” cable.
is it possible to use configuration “3”?
will there is no problem? I will connect “battery monitor 1” to “pixhawk cube connector power 1” & “battery monitor 2” to “pixhawk cube connector power 2”
Im planning to lift up heavy things so current draw will be severe. will this doubling battery monitor help me?
