but configuration “2” need “Y jack” but I dont have, and I have to order it and wait for “Y jack”
and now I already soldered my drone, so if I try configuration “1” I have to unscrew all drone and resolder it
so I question… is configuration “1” also safe?
I will use 6s LIPO 5000mah X 2 and I’m scared to burn the battery or drone when I connect the power.
I know current draw on the flight log will be incorrect but it does not matter to me.
your configuration is not good you will not get any details about voltage drop of battery 2.it is not recommended .in this case you are connecting the battery in parallel after power module at this point you also need connector parallel to series . it is better to you wait and use configuration 2. in parallel connection both battery should have same voltage and mAH.if both battery is not have same voltage it damage the battery
