Can you confirm what firmware you have flashed it with first of all ?
Secondly can you post a screen shot Or video of your com port for it.
The way it works now is very much different to before. As Philip said they Cube is now shipped blank and Chibios uses deferent drivers.
The chances of the cube being faulty are very very low. With the current releases there can be a little playing with the drivers to get it to behave especially if you have used one before.
@MadRC thanks for the reply. The two Cubes are brand new and never been flashed. They create a com port, but wonāt allow me to flash firmware. Iāve downloaded the latest drivers and reinstalled MP. Iām assuming the baud rate for usb is still 115200?
That worked! Thanks a lot.
So whereās the problem here? Is it the drivers? or QGroundControl? or PixHawk? I would say the PixHawk because I was able to connect other PixHawk cubes with QGroundControl, but not this one. But I am not sure if itās just the PixHawk.
When i try to upgrade to latest copter, during the fw download when"cheking comports" Computer cant connect back to the board. I get message āno board detectedā. I have cleaned old win drivers and installed them again, no help. Side note⦠On boot up, i noticed that if i have cube Black connected to mission Planner, MP cant find the board but if i connect after board boot up MP connects normally and i get all parameters etc. Cant load parameters to QGC or solex when starting either program. Will try again today and report if any progress. WIN10,cube Black.
