Are the pinouts on the 90amp power module of the pixhawk v2 the same as the pinouts on 30a power brick of the cube 2.1, I would like to use the older version 90A module on the cube 2.1. Think I will have to change the connectors to a jst gh for it to work
You can easily check the pinout with a multimeter
Ok, that info is not in print I guess
