Power the Cube. Power brick mini and Bec
Thank guys.
I will also be using a Matek PDB that has a 5v BEC and a current sensor (not a voltage sensor). So I’m thinking of using that bec and current sensor to connect to “Power 2” on the Cube.
What do you think?
Anyway, Power 2 will not be used unless Power 1 fails, is that correct?
