Hello Fellow Cube Pilot Friends,
I was having an erroneous Battery FailSafe isue where the copter on a fully charged 3S battery would failsafe. I found that the powerbrick that we receive with CubePilot orange has to be set as other in Sensor Type in Battery Monitor. I also checked “Add suggested settings for 4.0 and up up in Initial Parameter” window. thei enabled GeoFence. As a result, I believe I started getting “PreArm: fence requires position”. Am I correct in my assumption? Once I set Fence_enabe to 0. The preflight error “PreArm: fence requires position” disappeared. Am I correct in doing so?
Thanks in advance
