Hello all, I since I am using 4 in 1 ESC for my quad running a cube black, I decided to get rid of the power module. But I am getting some problems.
The ESC telemetry is not giving you current data. You have to use the current sensor and input in in the analog current pin.
I want to get on Herelink, in Qgroundcontrol and Solex both my battery voltage and 100% of remaining battery.
Then BATT_SUM_MASK to 6, what is a sum of monitor 1 and monitor 2. I made the following conf:
Monitor 1: So I can get the Current
I selected analog voltage and current
BATT_VOLT_PIN disactivated
BATT_CURR_PIN=3 (Pixhawk2_PM1)
Sensor:“Other”
Monitor 2: So I can get the voltage
BATT_MONITOR: 9 (ESC)
But it does not work.
Any ideas?
Thank you in advance
