Hi All,
Simply looking to set up the ProfiLED as a repeater light for the Here2 and Here3 once I merge across. So far I am only getting the default white lights out of the LEDs, meaning they are not getting the proper signal. I have been using the guide for the setup but have clearly missed something.
The test jig set up is as follows:
Here2 on I2C
Cube Black running AC 4.1.0DEV
Servo1 = 129
Servo2 = 132
BRD_PWM_COUNT = 2
NTF_LED_TYPES = 711
NTF_LED_LEN = 3
NTF_LED_OVERRIDE = 0
ProfiLED Header is connected as follows:
Yellow (Clock) = AUX 2
Green (Data) = AUX1
The only message I get in MMP is “RCOut: PWM:1-10” which does not include anything about the ProfiLEDs as it should so I am assuming I have made an address error. Any help greatly appreciated.
