QGC freezes mid flight in Stable Release
Cool if that did help.
I have some more inputs if you change something:
  1. the vehicle arrow is somehow below the camera symbols layer and is not visible if the vehicle crosses its previous flight path (e.g. on RTL after a mapping mission).
  2. it would be great if the maximum zoom could be controlled. I did try some Typha seeding with my drone and did fly only 5 m AGL and with a 2 m spacing. Unfortunately it was impossible to select the next waypoint (after battery change) on the flight screen because I could not zoom in far enough.
  3. please implement some things which are already in Mission Planner and which are great, e.g. set pwm values for servos and switch relays and choose a waypoint or change the vehicle speed.
