Yes, although if you can’t connect to QGC on your Herelink you’ll need to do it like I did on a laptop through the Config List in Mission Planner.
I don’t use Solex so can’t really comment but I suspect you may need to check that it is using Mavlink2 and confirm the baud rate.
