I am a mode 1 flyer and with the previous versions of the HereLink firmware I was able to do the Mission Planner/QGC radio calibration and with the exeption of having to reverse RC2 (pitch) everything worked fine
With the latest release I am not able to calibrate in Mission Planner or QGC. In QGC I get a message saying that the thottle channel is reversed and calibration has failed. In Mission Planner when I do the radio calibration pushing the throttle stick forward produces a low value of 1102 and pulling the stick back produces a high value of 1927.
I have tried recalbrating the sticks and SBUS on the HereLink numerious times to see if I have been doing something incorrectly but with no success. I tried reversing the stick movement in the SBUS calibration
I have also tried reversing the ArduPilot RCx parameters with no success
From what I can see there isnt any option to reverse the RC outputs on the HereLink.
Also, I changed the channel map in ArduPilot to suit mode 1 i.e. 1=roll, 2=throttle, 3=pitch, 4=yaw
Hi @Brett the device is currently configured for Mode 2. We will push an update with more features in Joystick Config shortly. Afterwards, you should be able to make changes you require.
hi,
What am i doing wrong?
after the sticks calibration , i only get the throttle movement in qgroundcontrol , the others sticks are not mapped . What can i do ?
I have a similar problem with the radio calibration. I does not work at all after the new update. When I try to do the calibration HW JS CAL nothing happens. I seems that the joysticks arent responding to anything. Everything worked perfect before the new update!
