There are some reason that I want to connect the Cube black to Raspberry by USB port for using the SR0_ (serial 0). I already known another methods by usual serial 1 or 2,3,4, but in this specific case, is the connection is feasible? If yes, there are some driver (STM32) for the raspberry, I guess!
Could you please show me the way to do?
Thanks in advance,
Vu.
EDIT:
I have some picture of these when plug Cube to RPi
EDIT2:
This is possible!
When you do ls /dev
we will see the Serial
or Serial1
by examining the “Shortcut”, it is directed to /dev/ttyACM0
. So we can consider it as a serial port. Just sometime after doing the Cube rebooting, the ttyACM0
will be changed to ttyACM1
and I dont knot how to fixed this? Because of non-releasing it after using or something?
Is there an issue with using the second device name from the beginning? Is the former name still there as well?
I do not understand much about the mechanism of Linux but if you plugout and plugin the device, the ttyACM0
will change to ttyACM1
but sometimes, it remains the same. So just do the ls /dev
and search for which ttyACMx
is presensted
Using USB in flight is not recommended
Hi @philip , thanks for your recommendation. I would like to understand further the reason why. Is is about physical connection or something?
Because the stability is not proven, and it’s not designed for this purpose.
That’s an Ardupilot thing, nothing to do with hardware
Usually autopilot power is switched to low power mode when USB is connected and usually USB power won’t be sufficient to run all devices. Why not use serial port?
