Is there anyone here who has used a VNC viewer through Herelink to get connected remotely with Rasp Pi . The Rasp Pi is used as a companion computer with Pixhawk for drone applications.
Yes I do it with a Jetson Xavier NX and it works OK as long as you set the video resolution correctly (1080/30).
Do you think it will work with Raspberry pi HQ camera
Well, the camera is a an input device so the capture resolution may differ from the output device (HDMI) that is feeding the Air Unit input Video. It is all a matter of being consistent in the streaming pipeline.
So you are saying here that I could see the Raspberry CAM HDMI video connected thro’ the Airlink through the Herelink if the streaming is correct .
I’m not doing that exactly, but I’m having success providing a UDP or TCP video port and using something like VLC (or more often in my case, a JavaScript front end) for viewing the video. It works OK, and there’s not much difference latency-wise between the normal and HQ cameras.
Hi
I’m trying the same as on my companion computer Jetson orin nano.
But it doen’t work for me. which IP will work for vnc viewer.?
Can you explain a bit on this?
I have herelink v 1.1 only
