Hello. I bought a new pc (windows 10). What does this warning mean? if I change the settings, they are not saved. Thanks.
This is normal. It means that those parameters are not verified for flight. You have to check/calibrate them carefully before having an actual flight.
Okay, thank you for the information.
The message is normal. You can un-tick the box if you don’t want the reminder every time, which presumably you’d done in the old laptop. When you say the parameters are not saved, did you click “write”?
