Reverting Herelink from a custom OEM build
I am trying to recycle a Herelink GCS and Air unit V1.0 that was running a custom OEM app on an aircraft I purchased. I removed this and need to use this on another build as I was unable to use the HDMI ports due to the custom app settings.
I had assumed I could download and run the flasher_win via USB to overwrite and restore the factory default settings. After re-flashing I get the registration and update page. I follow these prompts, but it looks like it’s updating the OEM version as it’s trying to update from FRU01240530 to FFARU01231123? It now gets stuck in a “installing system update” screen at 100% and I have left it for hours to install, tried to re-flash several time and run the update but no luck. Without updating I have no apps installed (Solex, QGC, etc) or Herelink setting tab to connect to the air radio.
Is there anyway to recover this unit to the factory supplied configuration?
Many Thanks
