Referencing a layout like this I have an issue I cannot figure out. The companion computer has a USB 2 Ethernet adapter and so eth1 exists. eth1 is on a 192.168.0.254/24. eth0 is on a 192.168.144.254/24.
Via eth0 I can talk to 192.168.43.0/24 via routing through the 192.168.144.0/24 as provided by v1.1.
I have a camera that is connected to the companion computer and the ip address of the camera is a 192.168.0.103.
As I understand it 192.168.0.X is an unusable subnet for the Herelink and thus what I want may be difficult.
I would like to use a route of 192.168.144.254 to reach 192.168.0.103 from the Herelink for UDP streaming of video. As I have root on the companion computer it is easy to forward the packets. I do not know if it is possible to modify the routing tables of the Herelink without root.
As I understand it in 2023, we are still prohibited from having root access.
What steps if any can be taken to modify the routing tables for the Herelink so that we can use a companion computer as a gateway? Assuming this can be done is a route to the 192.168.0.0/24 impossible?
