Recently received the Here4 base, I was hoping someone can provide recommendations on the best antenna to use as it doesn’t come with one, and the antenna can greatly effect performance
Hi @Mbuilds for Here4 base you need to ensure that you get L1/L5 GPS antenna and supports these bands: B1I, B2a, E1B/C, E5a, L1C/A, L1OF, L5. There is a wide range of antennas that can be attached to the Here4, the selection will depend on your use case and budget, just ensure it supports above specs.
