I am facing a problem with the RTK in mission planner.
I can connect to the RTK in the setup/optional hardware/rtk/gps inject, as you can see in the screenshot. But in the HUD the GPS status won’t change to RTK-fixed (GPS 2 is RTK-fixed through the moving-baseline setup). When I take a look in the mavlink inspector I also don’t see anything RTK related. I have tested it with two different RTK gps’ses (emlid & holybro), so it is not RTK related.
Mission planner is connected by UDP to the drone and all the other mavlink data is streaming well.
Does anyone have an idea, how to solve this issue.
Thanks in advance
Kind regards,
J
