Very strange problem on the Herelink Tx (v1.1). I notice when attempting to set up the control surfaces that the travel of the sticks did not seem to be completely working ie moving towards the extreme of the stick the servo stopped and this was the case in all extremes. I thought it was the calibration which I had done a few times but this all worked fine (both stick and SBUS). I then noticed the issue which was to do with the output on the SBUS was not getting to the limits (approximately 5% loss in each direction) in comparison to the raw transmitter outputs. Has anyone seen this before or have any ideas what I could do. Its almost as thought the SBUS calibration did not work.
hello, did you find any solution for this i am facing the same issue.
