Hi Everyone,
I’m trying to connect a sbus gimbal to my cube orange. I can’t seem to find a full description on how to do it. Where to plug it in/how to set it up ect. Any help would be greatly appreciated.
Thank you
Hi Everyone,
Thank you
You may check it from ardupilot wiki:
https://ardupilot.org/copter/docs/common-cameras-and-gimbals.html
Thank you for your help. I guess I have a two part question. First was gimbal setup and second was Sbuso setup. Thanks again.
You may check the sbuso setup from:
https://ardupilot.org/copter/docs/common-sbus-out.html
Perfect! Thank you
Hi Alvin,
Thank you for your help. I’m almost finished. I’m trying to set the gimbal up so the A button will pan one direction and the B will do the other. The only way I have found d to do it is use the C button for the default and the have to toggle from A to C and B to C. It’s not letting me setup 2 buttons for one channel. Any ideas?
Thanks again!
Shaun
This is because the Herelink buttons are not 3 ways buttons. You can’t assign multiple buttons to the same channel otherwise they will conflict with each other.
You will need to write a lua script to control a RCOUT from multiple RCIN;
or assign mavlink buttons with messages such as SERVO_OUTPUT_RAW
https://mavlink.io/en/messages/common.html#SERVO_OUTPUT_RAW
Thank you
