Hello, I am setting up a power system according to the diagram below, which consists of 2 16000mah 6s batteries in series. I am having trouble with the setup parameters. Below is the setup based on mauch’s documentation, with 6s battery the PL200 sensor will be connected in parallel and V div is 10.
When going through the sensor hub, V div is (V div sensor1 + V div sensor2)/2, and A/V is (A/V sensor1 + A/V sensor2). I would greatly appreciate your help!
