Once you’ve created a mission, go into the flight screen and switch to the map view. On the left, you’ll see a “Layers” button. Click that and click “Missions” in the list. You should see that list expand to show the missions you’ve created. Click one of those, and a panel should appear in the bottom center of the map. Click “Send” and it will upload the mission to the vehicle.
meanwhile, I want to congratulate the App which is really very well done
In fact, I hadn’t thought about this and focused on switching to radio control. On the other hand, everything is simpler … after being in “flight” mode I can launch it in the car both from the ground and after taking off
I could suggest creating a bar that “invites” the user to switch to “Fly” mode to continue managing the mission
That’s a good idea, actually. At some point soon, I’m going to revamp that flow because it does make Missions kind of “hidden” and I’ve had that question asked before. I’ll make it more obvious as to how you can actually fly what you’ve made.
