Hi Community, we are trying to connect Solex Tx(Version 1.2.3) in herelink with the plane firmware v4.3.0 with cube orange plus.
We are not using camera module with the setup.
Can this cause any issue with the connection?, Please advice how can we connect arduplane with the solex tx.
It’s saying “Looking for vehicle type : No Vehicle”
Hi, may I know the firmware and hardware version of your herelink controller and airunit ?
Did you try with QGC ?
Also can you share a picture of your set up if you do not mind ?
What is SolexTX doing when you try to connect? If it’s just sitting and showing “Looking for vehicle…”, then it’s not getting any packets from the vehicle. I would suggest trying QGC to see if it behaves differently. Also make sure QGC isn’t running in the background when you try to connect from SolexTX (and vice versa) because the UDP connection can’t be shared between applications.
Hi @Mike_ZY & @kellyschrock , below are the images for hardware configuration of herelink airunit with cube, we are providing 9V to the airunit(verified), both LED1 & LED2 are solid, SBUS is connected to RCIN in the cube, UART is connected to TELEM1.
Hi @Mike_ZY, the above image is the result after pressing the connect button on SolexTx app. there was no difference at all before or after clicking the connect button.
