This is my third attempt to articulate the problem i’m having with both a orange and purple cube in rover 4.0 setup on a boat. Everything is fine it even follows its planned lines. The problem is I must move the throttle stick above 50% to get it to run its mission in auto mode. To achieve My goal of 1m/s i need to put max throttle at 35% other wise it speeds off. I just dont think its correct to need to move the throttle at all to start a mission in auto mode. If the throttle is at 0 or one click when i hit the auto switch it seems to do a slow fidgeting or mild bucking so i do think its getting the command to start the mission. Also , I dont see any parameters for speed nudging or throttle nudging
