I have a cube black, herelink radio and a t-motor LV -ESC set. Is there a surefire way to calibrate the esc and have it work? Advice from someone who has done it successfully. Thank you ![]()
Is it the T-Motor Flame ESC ?
You cant calibrate, you need to set:
MOT_PWM_MIN,1100
MOT_PWM_MAX,1940
and use motor test to confirm and set values for:
MOT_SPIN_ARM
MOT_SPIN_MIN
Edit: the new specs say how to calibrate using a receiver but thatโs not ideal. Iโve not personally seen them calibrate, so the old way (above) may be the only valid method. Either way you still need to test and set the M_SPIN_ values.
Semi-Automatic ESC calibration:
