T motor velox v2 esc with pixhawk cube orange
Hi everyone
I am facing a problem during setup in orange cube. I am using sunnysky motors 1000kv in 450size quadcopter and also using t motor velox v2 45amp esc. Problem is , i have used the aux pins 1-4 on the mini cube carrier board and set the servo 33-36 pins for motor configurations and also using the dshot150 mode. When i armed the drone in althld mode , it started wobbling and the motors behaves like non calibrated. I have even off the low rpm motor mode in blhelisuite32. The problem still persists. Please help
Any one used this setup , please help
Wobbling has nothing to do with wiring. You need to tune the aircraft.
