I am having issues seeing any control input on mission planner. I am not sure if there is a parameter I have to change or something else I need to do in order to use an FrSky R-XSR receiver with this flight controller. I currently have the receiver plugged directly into the “RCin” port on the flight controller. I would greatly appreciate any and all help. Thanks!
That should be all, assuming it’s bound to a transmitter OK
You’ve got a suitable link LED, constant green?
You are using the SBUS_OUT and +5v and GND ?
Maybe check the transmitter is set to SBUS 16 channels too, maybe called D16 mode
