The Mini Carrier Board from CubePilot
i have just bought a mini carrier board for a project . I am reading in the doc’s that i should solder the pads to get sbus and 5v setup . what i like to know is this board already setup as default sbus and 5volts thank you so much for your help???
https://docs.cubepilot.org/user-guides/carrier-boards/mini-carrier-board#ppm-s.bus-signal-and-spkt-signal-switching
By default, Mini Carrier Board uses PPM and S.bus in RC IN
The middle solder pad of the left hand side is shorted with 5v pin.
thank you Alvin have a nice day…!!!
