Thermal testing on Cube Orange +
Has the Cube Orange + gone through thermal testing? Specifically looking for thermal cycling data and thermal survival data in extreme temperature conditions.
@philip @CraigElder
Yes it does.
As someone who’s worked with the Cube Orange in both lab and field conditions, I can confirm that thermal management is crucial, especially during extended operations or high-load processing. In my experience, it performs reliably up to around 60°C, but it’s good practice to monitor temps in real-time and use passive or active cooling (like small heatsinks or fans) if you’re in a warmer environment or running demanding workloads. Proper airflow around the carrier board also makes a noticeable difference. Just make sure you’re logging temperatures during test flights…that data can really help fine-tune your setup!
the problem is they test it to extreme temps but only spec it to -20 (cube black used to be speced to -30) so it does not matter what they test it to, you can only legally fly it at -20
I wish they would update that spec to -30 because -20 is a summers day up here.
