I am setting up my replacement HereLink ground unit that was sent to me as a RMA for a previous faulty unit. I do not know if this is a referbished or a new unit, but I am experiencing strange behavior. I have updated all firmware and was in the process of performing the HW JS CAL. We are using mode 2 with the left stick up and down as Throttle and left stick side to side as Rudder. The Rudder and Throttle movements appear to be swapped. When I move the Throttle (up and down) the Z axis moves in the main Joystick screen, and when I try to calibrate when I move the Throttle stick up it moves the little circle to the right. Move Throttle down moves circle to Left. When I move stick to the right, the little circle moves down, and when I move the sitck to the left the little circle moves up. Is this a hardware fault or some setting? The left stick (elevator and aileron) work correctly. Thanks.
In the phone status of the unit I have the following settings:
Can you please do the calibration one more time?
Maybe this time try to slowly move each joystick individually.
Did you try re-flash firmware or reset your herelink?
I tried the calibration a few more times, with the same result. I rebooted HereLink between calibrations. We did a factory reset of the HereLink and updated to latest firmware and it continues to exhibit the same behavior. If needed I can make another video, but it is operating the same as in the previous one. I have not reflashed the device, do you have instructions to perform this? The right stick has always moved as it should. Please advise.
I reflashed firmware a third time, and had to redo the joystick and sbus calibrations a couple times, but now it is working as expected. I plan to calibrate the ESC’s on the USV that we will be using this on today. I expect it should work. Thank you for your help.
