Is it possible to train with two Herelink, a master and a second slave to do learning?
Practically no… bcs there is no input for two S-bus… BUT what you can do is to use joystick feature of mission planner… you connect a joystick to pc and control it via pc… while trainee will do it from herelink… not tested but theoretically possible… BUT if you will use loiter FM thats very easy mode… put 3m/s speed limit low descent rate 0.5m/s 1.5 for climb than you can easyli intervene by yourself…
Ok,
I will continue to use a drone with two Frsky remote controls and then I will use the Herelink with another drone.
Thank you !
