Is it possible to use other UART ports of the cube orange as mavlink ?
I already read the docs that it is possible by assigning the serialx protocol to mavlink. But still confirm that is it possible. Here is my setup.
TELEM 1 port of cube orange ------------------> Herelink telemetry connected ( require mavlink )
TELEM 2 port of cube orange ------------------> Air commander entire connected ( require mavlink )
USB port of cube orange -------------------> Raspberry pi connected with UAVMATRIX software
for 4g control of drone (require mavlink)
GPS 1 port of cube orange ------------------> Need to connect raspberry pi (require mavlink)
GPS 2 port of cube orange --------------------> Need to connect another raspberry pi or nivida
( require mavlink)
So as you can see that these many mavlink needs to be assigned to the respective serial ports. Untill now I have seen mavlink 1 and mavlink 2. Where is mavlink 3, mavlink 4 and mavink 5 for USB, GPS 1 and GPS 2? As mavlink 1 for Telem 1, mavlink 2 for Telel 2, mavlink 3 for USB port, mavlink 4 for GPS 1, mavlink 5 for GPS 2. Because as much I know that mavlink 2 is running on telem 2 port then it can’t be used in GPS 1 port, Usb port, etc simultaneously. Because there are 5 mavlink devices to be connected as mentioned above but available are mavlink 1 and mavlink 2. But also need more mavlink. Am I wrong ? Is it possible to use mavlink 2 on telem 2 and same mavlink 2 on USB, GPS 1 and GPS 2. Any problem ? @Alvin
