Hi, can someone put up a guide on how to do display ADS-B tracks on the map using the PingUSB for non-programmer/coders types like myself? I know it can be easily done with UGCS, but I need it on Mission Planner. Thanks
Looks like uavionix already published a quick start guide on internet?
Not sure if it works because I don’t have one to test with
Thanks, but I’m looking for the ground side PingUSB. This is the air side setup.
I don’t get it. It says
the traffic should appear on the Mission Planner map
So what’s the matter for air side setup? It will appear in the ground side anyway
Or do you mean you want the ADSB show up in Mission Planner without using an actual autopilot?
Yes, i want the ADSB to show up in Mission Planner without using an actual autopilot. I want to use the pingUSB to display traffic on the Mission Planner map.
