hi,
after the update, i’m unable to use the ugreen cable via thethering usb
Any advice ?
Connecting to a screen using UGreen HDMI Cable.
Components Required:
- [ ] 1x Herelink Controller
- [ ] 1x UGreen USB to HDMI Digital AV Cable (UGreen PN: 50291)
- [ ] 1x Micro USB - USB A Cable
- [ ] 1x 3rd Party Screen with HDMI Input, eg TV, Monitor
- [ ] 1x USB Power Source (can also be on the TV/Monitor or separate)
- [ ] Camera Feed through Herelink Air Unit (optional)
Procedure:
- Turn on Herelink Controller
- Do not enter QGround Control or Solex
- Use centre android screen button to exit the app if you have opened the app
- On Herelink Controller In the bottom right corner tap the 6 little squares icon
- Tap “Settings” - Big Gear Icon
- Enable Developer Mode if not already enabled, by scrolling down to the bottom and tap on “About phone”
- Scroll down to bottom of page and tap “Build Number” 8 times.
A message will appear when Developer Mode is enabled. - Return back to “Settings”
- Scroll down and select “Developer Options”
- In Developer Options turn on USB Debugging
- Swipe down from the top edge of the screen to pull down Herelink Settings and Radio status.
- Tap on the big white square that now has all the Radio Status information listed. The Radio/Joystick/Buttons menu will appear.
- Under the Radio Tab, Scroll down to “Video Sharing” and ensure it is enabled
- Now connect UGreen HDMI connector to your chosen screen
- Connect the male USB A connector to a power source
- Connect the female USB A connector to a Micro USB lead
- Connect the Micro USB lead to the Micro USB port in the base of your Herelink Controller (You may receive a prompt to enable USB debugging, select “OK”)
- After about 10 seconds, Your 3rd party screen will now display the same as the Herelink Controller screen
Hi.
I am trying to find a company that will ship the UGreen usb to hdmi digital av adapter 50291 to USA. I can only find them in Australia. Is there another cable that will work? Looking for help finding one.
Thank you.
Hi David @dtd4485 ,
Bask Aerospace currently stock these cables on our webstore. We are able to ship to USA.
Best Regards,
Cameron
Ordered.
Thank you!
